Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
Thread: Breaking up under boost
  1. #11
    Apr 2011
    I had a issue with my truck would only do it under a load like explained. Once it was a bad spark plug then a wire another time. Last time I had this issue I checked every
    thing I could think of Ray ended up finding that the fuel pump under WOT would start to lose fuel pressure. The fuel pump was weak it was A1000 that had been hit by a drive shaft that caused it to go bad over time. So you might check your fuel pressure under a load.
    2006 Silverado aka (Bad Bitch)
    K&N CAI, Diablo Predator, muffler delete, and a vette servo. 14.7x @ 93 mph (sold)
    1998 SS Camaro aka (Silver Bullet)
    LS6 intake, ported TB, LTs, ORY, cut out, and a pantie dropping tune by Nelson. 12.6 @ 110 mph 327 hp 347 tq
    2011 ecsb silverado aka (silver sleeper)
    forged 6.2 and a small snail
  2. #12
    Ponca City
    Fuel psi is very constant. Plugs have be changed 3 times and regapped all over. It's not even making it to 8lbs before it breaks up. Idc is like 30%. Plugs don't show sign of detonation either
    Slowest in Oklahoma...
  3. #13
    Dec 2011
    Savannah, ga
    guy on ls1tech has this problem and it ended up being worn out valve springs, shouldn't be to hard to inspect them, not sure how you are supposed to test the spring pressure though while they are on the truck still
    1997 RCSB, AES 390 + 4L80E transplant, F1A Procharger, #160 injectors, Magnafuel 750, Schoenfield Longtubes, 3" flowmasters, Steve Morris Bullit cam, Circle D 3k stall, Ford 9" rear, Homemade Caltrac bars.
  4. #14
    Ponca City
    These are new lunati duals
  5. #15
    Ponca City
  6. #16
    Jun 2004
    george west texas
    sucks to have your very own 2 step all the time....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
  7. #17
    Ponca City
    Well did some internal digging...here's what I found. Each pic is at a different location around the reluctor wheel...
  8. #18
    Dec 2011
    Savannah, ga
    so what does that mean? that the problem?
  9. #19
    Nov 2009
    SAN ANTONE
    ive seen that before on a truck that had a similar issue. start tearing it apart and change it
  10. #20
    Ponca City
    On the to list. Talked to crank mfg and they said to send it back and they would make it right. Still sucks.
