Originally Posted by
flynaked
Ok I just went out and hammered it a lot and nothing, couldn't get it to do it, 3-4 stop lights too and nothing wierd. As soon as I got home and drop it down and it hits hard in park and hangs at 15-1600, I blip the throttle a little to see if it will come back down and nothing, so it just hung there and I shut it down. Sounding more like a vac leak huh?? Kind of wierd that its actually quite a bit different than earlier today only doing it in park and all. I haven't been able to check the IAC for function as I don't have anyone to hit the keep for me tonight. The TB was the only thing I changed before driving it again, everything else is stock lq9.
Question, is there any kind of spacer on the throttle shaft that mine is missing, I got this TB from a friend and never saw one when taking it apart, seems to maybe have a little side to side play in the shaft, not sure if its too much. Thanks for the input, much appreciated!
*couldn't find any spot in the throttle travel where the blade sticks on a hot or cold engine, so I think thats ruled out*
