Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 39 of 39
Thread: So. This has caused quite a stir.
  1. #31
    Quote Originally Posted by George C View Post
    something to consider about your truck
    LM7 with untouched 243s
    fast 102
    230/236 cam
    1 7/8 primary headers
    t56
    on 9 psi
    dyno'd 575 ish and went 12.0@117 1.7 60'
    think about it
    Oh you know I'm thinking about it.
    San Marcos Texas
    I guess I didn't state myself clearly "4L60 guys are just jealous" and I said sometimes you get a good one!
  3. #33
    hot & windy
    the way you said it makes it look like you think it's a gem of a find if you can get an nv3500 to hold together after a v8 swap, but what i'm saying is that after my years of research, reading up on builds, and even talking to some of the manufacturers, it's the exception to find one that craps out. my conclusions were that when behind comparable moderate-build engines, i've seen worlds more 4L60s that need rebuilds than 1/2ton 5speeds.
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
  4. #34
    Edmonton, AB, Canada
    Why dont Americans like metric? Its more straight forward than Standard.
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
  5. #35
    Sam reason I don't. Metric is f'ing gay.
    In its defense, a base 10 system is by far the easiest to work with. Same goes for fahrenheit and Celsius, why base your whole temperature system off body heat- Kelvin is better than celsius. There must be a reason Metric is used globally, the only reason we use standard is just so we can do buisness with you.
  7. #37
    hot & windy
    Quote Originally Posted by shmiet View Post
    ... why base your whole temperature system off body heat...
    because we're humans & believe the universe revolves around us
  8. #38
    My entire profession is based around miles, feet, inches, gallons and pounds. And degrees Celsius.
    Well put zebra haha.
    Lots of professions are based off it, Im just saying metric aint that bad. Even NASA uses it.
    I use both for designing parts, depending on the customer.
    Sorry for making an argument ill get back to building haha.
    BTW those are some good numbers, ill be posting mine after dynoing this Friday
