What's needed to fit a th350/th400 to a 4.8/5.3 motor? I know the bell housing will bolt up, but not using all the bolt holes on the motor.
The flex plate needs to be swapped. I believe B&M makes the one you need.
Ok cool I'll check it out, thanks.
Get the 6.0 flat flexplate and spacer. That's what I used. Got it all for around $70. I think I got it from pace performance.
99 Silverado 4.8l : Soon to be 80E swapped, then 6.0 swapped, ......
05 Yukon Denali 6.0l : Nelson Performance Tune, ......
8X S10 Blazer on a 8X 3/4 ton frame : 5.3l swapped, Nelson Performance tune, Schoenfeld LT's, 226/226 .598/.598 112, TH350, planetary doubler, NP 205, locker, spool, 38's, ......
