Results 1 to 6 of 6
Thread: Will this choke down my turbo or do you think this will work?
    Edmonton, AB, Canada
    Just debating wether or not this will allow enough flow for the turbo. Just where the crossover merges with the passenger manifold then to the turbo(too small of a diameter??). its a 72mm Magnum .96Ar. Thanks
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
    Sep 2011
    Some may say yes and some may say no but I'd go a different route if I were you.
    99 rcsb silverado...... boosted.
    Well where it joins up its almost 3" then it transitions to 3" then to the flange. What size pipe is typical?
    That is going to flow great!
    The kit will outflow the turbo!
    That looks about a 2.5" hole or so, if so; don't look back and move forward!
    you'll see how linear and well it flows when you're done!
    my kit on the avalanche wasn't exactly like that, the merge was between the turbo and flange, like a Y pipe (which yours is too); that big thing made 525hp on 11-12psi, Magnum 76mm, 48lb inj, walbro pump (stopped pushing it when fuel pressure started dropping), oh ya and the 6.0L i think, maybe the 5.3L i can't remember and don't care, lol.
    Point is, you'll enjoy it.
    Just what I needed to hear man, Thanks alot!
    San Marcos Texas
    It will work just fine but you will want a bigger turbo! 80MM to start with!
