Hey Guys,
I've just finished doing a shock relocation on the rear. Moved both to the rear and laid back between 1-1.5 *, shocks are single adjustable QA1's. The cross member is 1 3/4" x .120 wall D.O.M. All hardware is fine thread with ny-locks. I had to tilt the lower shock mounts by 15* to clear the sway bar. I will be removing the stock crossmember just behind this new one to make way for a db rods fuel cell Just wanting to see if any of you have any concern's or see anything I have missed before I burn this set up in for good.
