Not to pick on any body, as far as my opinion those should not
Whine. Ive installed numerous brand name sets of 4.56 even from Rons and never
Heard a whine or whistle
Agreed, a good set of gears setup correctly shouldn't make noise.
Unless they are used then you may have noise when slowing down/coasting. Because setting up the mesh on the load side for best results, your decel side may be slightly off due to wear.
2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
The gears were new from Ron, the setup on them was spot on, I have even changed the fluid in it with different weights, for general purpose's to see if the fluid was the culprit, NOTE: Mobil1 makes lots of sounds with an EATON Posi, must use plain jain cheap fluid for a no chatter rear along with the LS additive, and the conventional oil seems to net me the quietest results. But it is what it is.
I hear ya' on that. I'm not picking or bashing anybody's product. It's just odd that they make noise.
2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
Slowest in South Jersey ..........SOLD :-(
2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
i have bought a set of USA gears from Ron, they did whine more than i liked and i knew they were installed correctly, talked to Ron and he replaced them, new set same brand no whine
Simple: 408 on steroids!
single digits coming soon!
Installed new motor and trans, Can barely hear that sucker back there now
Good to know that there are still people that take care of their customers! Ron's sounds like a great place to business.
So when you gonna show us pics of this new motor in the carnage thread? Lol! Jk
99 rcsb silverado...... boosted.
