I'm going to pick up a 9" housing and center section this weekend. I plan on putting a good set of axles and a spool in it. I've got a few 10 bolts laying around and planned on using the spring and shock mounts from. What brand axles and spool should I get? Will the stock center section hold up? Will I have to shorten anything? And what is everyone doing for brakes? Do I need to reinforce the housing any since I'll be leaving on the trans brake?
