well had a bad day today and fired the truck up and heard more noise then usuall, i popped off the oil fil cap and noticed the valleys and springs looked very dry, so i need a new oil pump, i'm an idiot for not doing it in the first place but i was running low on funds from everything else and figured the oil pump would still be good. guess i was wrong.
mods are in the sig but should i stick with a stock replacement or go with a high pressure? i'm not using a high volume since the entire oil system is stock and i dont want to starve it.
