You would think after all these years
Someone would have developed a solenoid durable enough to mount above the valve and spring to open the valve. No more cams. Tune your lift. Maybe one day
BMW did..... Piezo crystals is what they used and it worked but wasn't anywhere near cost effective and the crystals had a short lifespan, it's actually pretty interesting if you have some time to look it up
You dont even need an electronic solenoid. I had ideas for an oil pressure driven piston to push open the valves. Unfortunately, the new Fiat 500's use something similar. Guess I'm not so smart
- You may not post replies
- You may not edit your posts
