Results 1 to 9 of 9
Thread: 10" Rear Axle Off Center-This Normal?
    Oct 2003
    Question 10" Rear Axle Off Center-This Normal?
    Had a guy install my rebuilt 10" rear axle under my '96 2WD shortbed. The right rear tire sticks out an inch farthur than the left rear. Is this normal? (Maybe I put my bed back on a little to one side?) Thanx
    Jan 2012
    DFW, TEXAS
    well if it wasnt 1 inch off before then... i would say its off. my truck was off from factory. goggle 'chevy lean' all truck are gonna be off to some degree
    Arizona/Utah
    Pix would be helpful. Sounds a little goofy.
    Probably been wreck and got the dog walk goin on.
    Oct 2003
    Truck has 40,xxx original miles & never wrecked. Guess I could simply measure out from the frame on both sides to see if they're the same. If its off center, do I just loosen the U-bolts & wiggle it over, or is there locating brackets/pins or something, that will not allow me to do this? thanx
    Possible, but like u said could be the bed. The guy who traded erica beds still hasnt straightened his bed and looks like its dog walkin!
    Round Rock, Texas
    The axle plates have holes where the center pins in the springs locate the axle under the truck.
    Oct 2003
    Quote Originally Posted by Duct_tape123 View Post
    O.K., Good to know. My axle is now on the top of my leaf springs(axle flip), would this still apply? Thanks again.
    it should still apply. The bed may be a little off center
