Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: Launch?
  1. #21
    Dec 2009
    DIrty south AZ
    Ill have to dig into it alittle more. I dont know much about the tuning thing. That othwr truck i posted is what im trying to achive. I know our trucks arnt rhe exact same but i should have alittle more power than his? Idk just seems off to me?
  2. #22
    Aug 2012
    Mount Pleasant, Tx
    You notice his shift extensions are right at 5k also he is probably reving 6.5K or so because there is a bit of a pause at 6k. Yes his converter is a 3.5K which will make his extensions higher then yours by default, especially if its a smaller diameter stall. But rev that sucker a hair higher and make sure your not tapping limiter, do a log of some kind if you can.
  3. #23
    Aug 2012
    Mount Pleasant, Tx
    Quote Originally Posted by darnie1987 View Post
    Your truck being a 4wd and running 33's is not helping in the least. His stall is the really advantage he has over your truck mod wise.
  4. #24
    Dec 2009
    DIrty south AZ
    Ya that and the cam. But cam wise im sure i make up for it with the heads, and the manifold. So ya gears and 300 more stall? Just seems like a huge diff between his and mine.
  5. #25
    Dec 2009
    DIrty south AZ
    Would fuel have anything to do with it? I have tbss injectors and have been planning on getting a warbro but haven't been able to yet?
