Need a good radiator repair company fast its averaging 110 & i caught something in my radiator causing a small crack.
Any suggestions? Or sound i try a clogger/stop leak first?
Dont try rad leak stop, ive seen several blow head gaskets cuz of that stuff. Is that the end tank that cracked or the center core?
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
- 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
Shopping List
- Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
I have a local shop here that does nothing but AC and radiator work. Surely you can find something like that around there. Just ask all the old car guys around your area. They know all the little places like that.
if the crack is on the aluminum, any good aluminum welding shop can handle it.
they probably clear some of the fins out of the way, then weld it up, so expect a little "destroying" of the radiator, depending on where the crack is.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
