Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 33
Thread: Door speakers
  1. #11
    Mar 2010
    San Antonio, Tx
    Ive heard really good things about Digital Designs components. I have some crappy MDX's but they are better than stock.
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
  2. #12
    Quote Originally Posted by screaminchicken View Post
    You cannot go wrong with anything from digital designs. Very vert high quality stuff.
  3. #13
    Wichita Falls, TX
    I have never heard bad things about any of the brands mentioned. Be sure and get an amp with enough power to push said component system, your aftermarket deck just won't be enough (for best sound quality).
  4. #14
    Dec 2009
    DIrty south AZ
    no to highjack the thread but i got the type S component set and they sound pretty good but i was jw whats a good amp for them im running them and clerion 6x9's in the back?
    Built 2 Run! 6XX HP/ 6XX TQ
  5. #15
    Wichita Falls, TX
    Just make sure your amp rms output matches the power handling of your speakers. Example. A pair of four speakers that can handle 75w rms each need a four channel amp that pushes 75w rms per channel.
    Brand is personal preference for the most part. Pay the most attention to the rms power. Sony xplod amps are labelled with their max wattage, rms on a 1000w Sony xplod amp is only about 200-300 watts. A Rockford Fosgate power 500.1 actually pushes 650-750 watts rms. In other words, don't fall for the gimmick, research and buy a good amp. I like Rockford punch and power amps because they are powerful, efficient, and leave a small footprint.
  6. #16
    Oct 2011
    Just put a nice set of components in my G8, Polk's for $200, I really like them.
  7. #17
    Dec 2009
    DIrty south AZ
    these are what i got: SPR-17S ALPINE 6.5" TYPE R COMPONENT SPEAKERS SPR17S
    Type-R 6-1/2" 2-way Component System
    Power Handling:
    Peak: 660 watts per set / 330 watts each side
    RMS: 220 watts per set / 110 watts each side
    Impedance: 4 ohms
    Hybrid layered-pulp woofer with rubber surround
    1" Textile ring-dome tweeter
    External crossovers — 12 dB/octave (high -pass) and 6 dB/octave (low-pass) crossover points
    Frequency response: 65 Hz - 27 kHz
    Sensitivity: 87 dB
    Top-mount depth: 2-5/16"
  8. #18
    Oct 2011
    San Antonio TX
    Quote Originally Posted by darnie1987 View Post
    Power Handling:
    Impedance: 4 ohms
    External crossovers 12 dB/octave (high -pass) and 6 dB/octave (low-pass) crossover points
    Sensitivity: 87 dB
    These are the same ones i got n i love em. Got a alpine 55 x 4 Watt rms running them and they will make ur ears bleed at half volume.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  9. #19
    Dec 2009
    DIrty south AZ
    nice... well now i know what to get
  10. #20
    Not to hijack Ray, but what do people usually go with to replace with stock speakers with something other than components? In case they dont want to use an amp to power the speakers.
