with the traction issues i have just on motor at the track
she is now leveled on all 4 corners!!
already feel a huge difference on the streets!
Simple: 408 on steroids!
single digits coming soon!
Hey I have those same ones on the front! Looks good David, and yeah it does drive way better with those!
Nice david. Guys how does it feel at high speed. 120+?
mine rides grate at 150+, my setup is a bit different but coilovers none the less. Thats the nice thing about Jon's suspension setups, even if you don't need the extra traction they are awesome to have because of how much smoother the truck rides. Not to mention you have a lot less suspension travel with coilovers so you can get the rear end closer to the frame/bed and the front closer as well and not have to worry about contact
Id like to see that on gmt900
X2^^^. Looks damn good. Now hurry up n make em for 07+.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
Nice! I am goin to talk to jon about a fuel cell for the Plymouth!
there is no way to make a "bolt in kit" we looked at it at length with mine and even though i converted to rwd we had to build lower control arms and cut off the upper sock mount out then make a new mount for the coilover. 4wd-2wd conversion is not fun at all, tbh i would have been better off selling the truck and buying a 2wd and i still wish i had.
