Results 1 to 8 of 8
Thread: Edelbrock manifold question
    Apr 2012
    So I have been looking at going to a new intake manifold. I already have a cam, long tubes, Tune and will be going to forced induction sometime in the future. I have been looking at the FAST intake (the tall one for the lsx). But I also like the edelbrock PRO-FLO Xt. I was curious what else I would need to use the edelbrock intake. It says it is for a 90mm. Will I need an adapter plate? Do I have to swap the water pump and grind down the accessory brackets like I would if I was changing over to a ls1/ls6 manifold? Will the fuel rails etc work. Is it taller or shorter then the factory 5.3 manifold. Just trying to get a list together so I can do the swap on a weekend and have my truck back on the road by a Monday in time for work. Also if anyone has any pictures of one installed that would be great.
    2006 CCSB 5.3 Calspeed LT, CAI, Nelson tuned, 3'' exhaust
    Jan 2011
    Mcalester,okla.
    U will need a 90mm tb. And u have to use the edelbrock fuel rails kit #24-3629. Everything else is plug and play. I run the same setup. Except i use the edelbrock tb two
    Apr 2012
    How do you like the 90mm throttle body?
    Apr 2012
    Also if there was a way you could post a picture I would really appreciate it.
    Jan 2011
    Mcalester,okla.
    Will do and i love it
    Jan 2011
    Mcalester,okla.
    Apr 2012
    Holy Crap that looks good. Thanks bud!
    Jan 2011
    Mcalester,okla.
    No prob
