Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 59
Thread: Does the ECM neccessarily need the signal?
  1. #11
    Aug 2011
    Galveston, Texas
    Well. Yeah that's what I heard and though too. I got my ECM tuned from Nelson. but it doesn't. runs like crap when the AC is on. So.. Im wondering if I pigtail a wire off the clutch positive to the AC request pin on the red ECM connector that might solve the issue? No idea. but I ordered 25 pins today to give it a shot. Cant hurt?
    1992 Full size blazer 5.3 Swap successful.
    http://www.ls1truck.com/forums/lsx-t...zer-build.html
    Galveston, Texas
  2. #12
    Mar 2012
    Good luck! If u have good results let me know! Cuz I don't want my fresh 5.3 to he a turd when the AC is on!! Nor do I want to suffer in this ridiculous Virginia humidity!!!
  3. #13
    May 2010
    Galveston, Tx
    Quote Originally Posted by Clayman View Post
    I don't want to hear anyone complain about humidity
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  4. #14
    Mar 2012
    Quote Originally Posted by silverado_lover View Post
    Haha va is pretty bad may-September!!! Where are u comin from?
  5. #15
    Broken Bow, OK
    If you were using a 99-02 PCM you could give the PCM control of the AC clutch circuit through a relay and use your HVAC controller to provide a request from the PCM.
    The 2005 PCM requires a serial request for HVAC functions though. Been asking HPtuners to provide a setting for the 03+ controllers for awhile. As far as I know nothing has been done so far. I haven't been keeping up with it for the past few months though.
  6. #16
    May 2010
    Galveston, Tx
    Currently at 83% humidity...and I don't have my A/C lines made yet
  7. #17
    Aug 2011
    Galveston, Texas
    I second that. Were miles apart. Its HELLA hot. And the LS even though runs like a champ with no AC runs like a POS with it on. So it really needs to be addressed. I am running a drive by cable setup. Nelson provided the ECM. Does this mean its the kind I can work with?
    Galveston, Texas
  8. #18
    May 2010
    Galveston, Tx
    Maybe you could some how splice into the e fan wire that tells the fans when the AC is turned on and run the wire from it to the PCM for it to bump idle up?
  9. #19
    Mar 2012
    Today in roanoke it was 87+/- with about 85% humidity so I feel your pain!!! Im using my old AC lines so I should be good whenever I get the thing running
  10. #20
    Jan 2012
    Maybe splice into the clutch circuit and take that to pcm?
