Its the 6.2 L head, casting number is 823, theyre square port and flow better, you have to change intakes, and sometimes ptv can be an issue.
01 GMC REG CAB BUILDING
06 SILVERADO SS 80E 3200 YANK LS3 TOP, DD
2013 POLARIS RANGER CREW LE EPS
so i am thinking of getting a 799 head and swapping the comp springs i have onto them. i heard that ls7 lifters and pushrods are a cheap good upgrade. looking into a cam in the 230ish range and with good lift. and a nnbs intake swap with 90 mm throttle body. what do you guys got to add or say about this setup?? also what year and motor do i want a nnbs intake from?? looking a rock auto and need a year and truck and engine to know which one to get. Thanks
2007 and up I believe.
Ls7lifters yes pushrods no. Nnbs intake from a 5.3/4.8.... You can get 799/243 heads off the same truck as the intake.
Yeah I think the LS7 pushrods are 3/8" not 5/16".
ok good to fnd out now!! lol and when swapping to a nnbs intake do all the fuel rails and vacum lines i have now swap over? or is there more to this swp then just buying a intake??
also when doing all of this i need new gasket and head bolts, what are good brands that you guys use?? and what pushrods are a good upgrade for 220 to 230ish duration and 575 to 600 lift cam? and will the comp springs i got for the smaller cam i got now work on a bigger one??? thanks guys
