Results 1 to 10 of 13
Thread: LIft kit Ideas
    Feb 2012
    San Antonio,TX
    LIft kit Ideas
    Are there any true 8" suspension lifts out there I have been looking and I am not having any luck..Also if I do 37x13.50x18 do I need to beef up the gears or will OEM be good???
    Sep 2011
    456 gears ftw!
    Oct 2011
    San Antonio TX
    X2^^^
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Orono, ME
    I see on your one other post you say you've got an 04 Suburban, is that the truck you're inquiring about? There are a lot of variables when it comes to lift kits but a few I would recommend for the height you're seeking are the 7" Full Throttle lift, the 9.5" Full Throttle lift, the 6" Fabtech, or the 7" Cognito kit.
    2012 Honda Civic Si - DD
    Mar 2010
    Midland, TX
    ^^^ What he said plus options of a solid axle swap. ORU has some sick SAS Swap kits.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
    Sep 2011
    Michigan
    Atleast 4.56 gears I have a 6" with 35/12.50/20s and I am thinking about 4.88s. The truck has the stock 3.73
    I am going to agree with the Cognito kit. It is a 7-9" kit depending on how much you crank the torsions. And with the 37s I would go with 4.88 gears
    My last truck was an 05 ccsb 5.3, auto, 4.10 gears. It had a pro comp 6" lift, 35" tires. The truck had no balls, I swapped to a 4.88 and it was much better. The truck was a 4x4 as well, I took it to a shop and had front and rear changed out cost me just over $3,000 parts and labor.
    Aug 2011
    Ellsworth Air Force Base, SD
    There are alot of good calculators and charts for use on this and they are all pretty much the same with final results. Pirate 4X4 has alot of reference on this subject. Here is a chart that I keep in my garage and has worked extremely well in all the setups that I applied in too.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    Sep 2010
    I'd go cognito as well. They are well made. I have a 02 Yukon XL with 4.10's on 33's and it goes ok. I don't want any more rpm since it is mostly a family highway vehicle. So I put a YANK 2600 in it to help out with the off the line. My last truck (05 ECSB 2wd) had 35's and 4.56's and it moved well. If I was doing more commuting I would have gone 4.30. My buddy's truck (check long travel truck in for sale section) has 4.88's and 37's and it was almost a necessity. Partly cause it is a 4.8L with a 224 cam and 4000 stall, there is a lot of weight to get moving with not much torque.
    So IMO if it's going to see a bit of highway time, go 4.56
    If you want the power or are towing go 4.88
    @J_Industries ON INSTGRAM
    TURBO MIC PERFORMANCE
    MAZZULLA OFF-ROAD
    KING SHOCKS
    [HOONIGAN]
