Need some help with PCM pins
Im trying to install e fans and my connectors to my pcm are missing the pins for low speed fan and high speed. Can I buy the pins or can I rob some from another spot for the fan controls. C1 pin 42 low speed relay C2 pin 33 high speed relay in the empty spots I have
You can buy those pins at NAPA or the chevy dealer, they are Metri-Pak terminals. They are about 50 cents a piece, or If you buy them in bags of 100 they are only 10 cents a piece. You also need a special crimper to be able to do those, I have a MSD ratcheting crimpers for those. I would suggest trying to find a pair to borrow or something, as they're about $80.00 a pair.
Thanks a lot. i will run to napa and grab some.
- You may not post replies
- You may not edit your posts
