Results 1 to 10 of 18
Thread: Will flex fuel parts work on 2000 5.3?
    Hi i'm new to the forum i searched an didn't come up with much on this and i need some help/advice. I have a 2000 z71 with a 5.3. I'm doing a rebuild an making some changes. I already have a comp thumper cam, .30 over hyper. pistons, Lt headers, and I was wondering if i could buy the flex fuel, injectors, rails, tb, an intake manifold off a 2011 5.3 on my 2000? And how much I would benefit from it.
    Thanks Brandon
    Yes, need an Xlink for the TB.
    Its a 2000, he has the cable TB so no need for the xlink although you would need a 90mm cable style TB.
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Quote Originally Posted by graysilverado5.3 View Post
    Good looking out. I didn't even notice he said 2000.
    Houston
    good luck with the hyper pistons... and like said before that TB wont work you will need to get a Drive by cable one, the edelbrocks are a decent price and a good piece
    Quote Originally Posted by 408.Luke View Post
    Is there something wrong with Hypereutectic Pistons?
    -Ol Bessy-
    2000 Chevy Silverado 5.3 stepside 4x4
    k&n Intake
    PaceSetter Long tubes
    Tune
    Built 4L60e
    Detroit locker, moser axles
    Houston
    Quote Originally Posted by 5.3olbessyZ71 View Post
    yes, they dont like any kind of detonation, they wont hold nitrous if you ever want to go that route and you better have your tune spot on or it will be detrimental. had a friend that lost a motor in less than 20 miles from losing spark in a cylinder. IMO id sell them and get some forged and save the headache
    Thanks for the heads up on the pistons man. I will definately look into a set of forged pistons.
    One more question. So the injectors and fuel rails are a direct drop in? Just need a tune to run them? or will it just run rich in the meantime?
    I looked into the 90mm TB from Edelbrock. Looks like a good product, are there any other manufactuerers you would recommend for a 90mm cable TB?
    Also, what is the size of the stock 2000 5.3 throttle body?
    -Ol Bessy-
    k&n Intake
    Tune
    Built 4L60e
    Houston
    Nick williams makes a really nice 90mm theres some other brands around like fast. For the injectors you may need to change injector pig tails someone else may want to chime in on that
    Thank you I will do some more looking around at TB's. Ill wait to hear from someone about the injectors. Thanks.
    -Ol Bessy-
    k&n Intake
    Tune
    Built 4L60e
