Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: 5.3 misfires, can't find the problem!
  1. #21
    Jan 2012
    ok, coil swap tonight, will report back. Thanks for the advice!
  2. #22
    Florida
    Clean the MAF sensor. What brand plugs you running? Check for leaks on that cylinder.
    '04 Silverado RCSB with a crank bolt.
    You know your truck sounds good when cops ask you to get on it.
    Idle Clip
  3. #23
    Jan 2012
    RESOLVED! Swapped ignition coils 4 to 2 and vice versa, was beside myself when I read the misfire on cylander 2 code! Ordered new coil and will swap soon. While many said i should have started here, it was nice to have a chance to verify the function of the rings, injectors, and other coils. Computer is off to blackbear now that issues are resolved. Thanks to everyone for their help!
