Page 11 of 13 FirstFirst ... 9 10 11 12 13 LastLast
Results 101 to 110 of 122
Thread: 97 RCSB 6.0L + 4L80E + Procharger swap:)
  1. #101
    Dec 2011
    Savannah, ga
    Quote Originally Posted by tonheib350 View Post
    Hey MattC give me the lowdown on the 97 6.0 swap and what I need to do the swap I have a 97 C1500 Suburban that I want to do the same thing too. My email is bbenson7146@gmail.com....send me some play by play photos if you took any as you went along
    here are most of the pictures i took. pretty much need an engine, harness, motor mounts slide the crossmember back and a new driveshaft, headers. most of the stock stuff will work like the radiator and that stuff.
    http://smg.photobucket.com/user/haul...?sort=3&page=1
    1997 RCSB, AES 390 + 4L80E transplant, F1A Procharger, #160 injectors, Magnafuel 750, Schoenfield Longtubes, 3" flowmasters, Steve Morris Bullit cam, Circle D 3k stall, Ford 9" rear, Homemade Caltrac bars.
  2. #102
    Dec 2011
    Savannah, ga
    time to get some shit going!
  3. #103
    Dec 2011
    Savannah, ga
    got a set of holley valve covers for free and got the HOB bracket and F1-a mounted and ductwork ran, still need to mount the big red valve and run the fuel system, just waiting on fittings from summit.
    and the Garden hose i ordered haha
  4. #104
    Dec 2011
    Savannah, ga
    these AN fittings and hose ends are killing me lol they are the most expensive part of the whole fuel system and its the cheaper summit versions!!!!
  5. #105
    Pittsburgh, PA
    hey man thanks for the setup, I made a small thread and posted a video of it idling...good luck on yours
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  6. #106
    Dec 2011
    Savannah, ga
    got everything mounted and no leaks that i can find
    list of crap
    20 gallong ebay fuel cell
    Aeromotive A1000 +100, 10 micron filters
    Aeromotive boost ref regulator
    Holley EFI fuel rails
    -10 feed line to spliter
    -8 to rails and return
    a shit ton of AN fittings
  7. #107
    Dec 2011
    Savannah, ga
    finally got around to relocating the battery to the bed and installing the Big red valve, which sounds fucking awesome btw...
    https://www.youtube.com/watch?v=yCQcIfsWakQ
  8. #108
    Jan 2014
    Las Cruces NM
    Nice build
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
  9. #109
    Edmonton, AB, Canada
    If you want to drop the cost of AN fittings get JIC 37deg fittings. They are interchangeable. Although JIC is typically steel and not as pretty.
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
  10. #110
    hey matt, sent you a pm since my emails aren't making it to you.
    lmk.
