Results 1 to 7 of 7
Thread: Switched 12v
    Cedar Park, TX
    Switched 12v
    OK, so I ran all of the wiring for my new subs and amp. I'm using the factory head unit, and a hi-to-low converter. The high to low converter provides me with a remote lead for the amp whenever the hi to low converter is powered on. I have the converter behind the head unit in the dash, and I was wondering if anybody knew of a 12v lead back there somewhere that could be used for the converter.
    BTW this is in an '08 Silverado LT with Onstar, withOUT Bose. No navigation, just the CD player head unit with the AUX in.
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Quote Originally Posted by jetersaurous View Post
    I ran a switched power wire from the fuse box under the hood into the cab and made a small distribution block for all my ACC wires. There are no fuses inside that are switched that I know of.
    Cedar Park, TX
    Alright, i thought about doing that if I had to. Do you know which wire going into the back of the factory head unit is switched? There HAS to be one, right?
    There does have to be one, but I didn't bother to check which one when I installed my aftermarket HU. I already had the switched power block from under the hood from my gauge and nitrous install. I didn't bother to check, sorry.
    Get your self a test light touch one pin in the factory harness at a time with the key on when it lights up turn the key off if it goes off then there is your switched output make sure to ground the test light real good on something under the dash are door jamb
    May 2011
    Rockwall TX
    Go to the ignition harness and check the Pink wire for switched 12V, it should be good to go.
    TVS=
    Cedar Park, TX
    Quote Originally Posted by sully View Post
    Win! Thank you.
    R.I.P Blue '02
    '08 - 5.3
