Thread: Drivehsaft length for 4L80e
    Mar 2010
    San Antonio, Tx
    I am doing an 80e swap in my '02 ECSB and I am getting the trans and some parts from a 2001 3/4 ton RCLB 2wd. I am wondering if the driveshaft length for an extended cab short box with an 80e and 10 bolt is the same as a regular cab long bed with 80e and 14bolt. I can get the yokes, driveshaft, and flexplate from it. Any help is appreciated, thanks!
    2002 ECSB 2WD 5.3
    1995 Formula Firebird 383 LT1
    1984 Camaro 408 SBC
    Most sports require one ball, motocross requires two.
    Racing isn't a matter of life and death, it's much more important than that.
    Oct 2009
    Odessa, TX
    Keep your stock drive shaft and just change the front yoke on it.
    There is a yoke that will fit the 4l80 and your stock drive shaft
    99 GMC - RCSB 408 w/98mm whistle... WSLS Racing...
    Mar 2010
    San Antonio, Tx
    Quote Originally Posted by 00Z71 View Post
    I want the 3/4 shaft so I can use 1350 yokes because it's stronger and my stock one is a 2 piece, I've already popped two yokes so I need to go bigger.
    2002 ECSB 2WD 5.3
    1984 Camaro 408 SBC
