Results 1 to 10 of 15
Thread: 5.3 upper water pipe
    May 2011
    Could use some help with how to remove the upper water pipe on a 2004 5.3 (want to modify the pipe)
    Thanks
    Upper water pipe? The steam vent that goes from head to head? If so, two little hex bolts on each head hold the fittings down.
    Apr 2006
    Bellevue, Nebraska
    Or are you talking about the upper pipe on the water pump?
    May 2011
    Sorry, should have been clearer...the upper pipe to water pump. Thanks
    IS that the one going to your heater core.
    01 GMC REG CAB BUILDING
    06 SILVERADO SS 80E 3200 YANK LS3 TOP, DD
    2013 POLARIS RANGER CREW LE EPS
    Quote Originally Posted by A PATRIOT View Post
    "MOLON LABE"
    May 2011
    No...it goes to the radiator (pipe in picture)
    Sep 2010
    Im pretty sure they are pressed in, why do you want to do to it and why?
    i turned mine to clear a re-located a/c compressor. i just used a propane torch to heat the aluminum. it got very loose, would have pulled out easily. id imagine you could heat back up to put back in. you can barely see it in this pic, its pointed straight forward now
    May 2011
    Quote Originally Posted by Jess View Post
    Using the engine in a 63 Nova and want to route the radiator hose towards the drivers side and point downward
    Apr 2006
    Bellevue, Nebraska
    If nothing else, maybe cut and bead roll the existing pipe the use a mandrel bent pipe connect with hose and clamps. Unless you're going for the clean look of a well made turnaround pipe
