well I made it to the track last night. It was about 90* and humid as hell. Anyway the first pass was on 11psi with the 2 step set to 3,000. Here are the results
I then turned it up to 14psi and turned the 2 step up to 3,200. I was running pig rich, like high 10's and I ran 11.54@119.73 with a 1.72 60' and it was spinning to the 60'.
Next run was the best run. didnt touch the boost regulator but I just pulled 5% fuel out of the whole table. AFR's were perfect 11.5-11.7. My IAT's got up to 151 so the back half of the track was only with 10* of timing. Here is the results from that run.
Only on 14psi!! and I have to fool with the trans governor bc its at 5800. So its got 10s in it easily and I think it did pretty good for the first time out.
Ill have a video up soon!
Thats awesome, but man 151* is hot! Are you running meth or anything of the like? Either way great times!
Hell yeah I knew it was gonna be in the low 11's its got a 10 in it for sure! I'm still fighting a few issues but I got it rolling again. Now I'm getting a rattling in the front of the engine.... I'm putting this project on hold and buying a new daily!
No meth yet. I know it will help a lot. What's going on with your engine Jansen?
Sounded like an idler pulley going bad but I took the belt off and ran it and the sound is coming from the front of the engine.
Uh oh. What all is done to the engine? And ducky, can you update me on the list please sir
Sick times man! Get a meth kit and the tuning dialed and get that 10 sec time slip!
49 Ford F1
