Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: engine startup and no oil pressure... NEED HELP!!!
  1. #11
    Nov 2011
    NH
    so i think i figured it out guys. when i put the double roller timing chain set on it moved the oil pump out a bout a 1/8 to 1/4 inch. and the oil pickup got moved just enough so that it set a little sideways and was breaking the seal. so i pulled it all off and am putting the stock one back in to see if it fixes the problem. but i want to run the double roller setup so what do i have to do?? pull the whole engine to get to the pickup to bed it enough to lineup??
  2. #12
    you need to slot the mounting points on the pickup tube so that it moves forward to meet the new mounting hole location.
