Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: 1/4 MILE
  1. #11
    Jun 2005
    i would have to guess mid to low 12's without the gas given that u have the motor tuned good. i have almost the same truck 00 reg cab with a lq9 in it. i don't have as many mods as you and still manged to pull a 12.74@ 105 on a custom tune set up for my old heads and cam 5.3. n/a no boost no juice
    00 RCSB 6.0L, 222/224 CC, C/A, LT'S, PORTED TB, TB CONVERTOR, CUT OUTS, 3.73
    12.74 @ 105 n/a
  2. #12
    Mar 2005
    i have the hot 93 tune from nelson performance.
    2000 RCSB SS 2WD 6.0L LQ9 4L60E
    LS6 INTAKE, MSD WIRE, 80MM BBK THROTTLE, AIR AID THROTTLE BODY SPACER, BODY, 80MM SLP AIR METER, 36LBS INJECTORS, LS1 ELECTRIC FANS, YANK 3200 STALL, 4.10 GEAR, FAST FUEL RAILS, COMP CAM .224 .230 .581 .592 114LSA WITH 918 SPRINGS, PACESETTER LT HEADERS, 3" EXHAUST DUAL SUPER 40 FLOWMASTERS AND CUTOUTS, NELSON TUNE, SLP 160 THERMOSTAT, THROTTLE BODY BYPASS AND NO EGR OR CATALYTIC CONVERTERS.
    4L60E WITH STAGE 2 SHIFT KIT AND VETTER SERVO
    FUTURE MODS: STAGE 2 HEADS, SUPERCHARGER, UNDERDRIVE PULLEYS AND A 6 SPEED TRANS
