Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 77
Thread: Lextech's A/C Bracket Kit
  1. #21
    Nice kit, everything lines up perfect. Thanks lextech for all the help getting this thing going.
  2. #22
    Sep 2009
    NE Ohio
    Thanks for the nice looking kit Jeff. I know I wont be disappointed when I get this thing on my motor.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  3. #23
    Mar 2014
    Been lurking on here for a couple months now and getting close to wrapping up my 98 GMC Sierra RCSB 5.3 swap. Still have these kits available?
  4. #24
    May 2007
    Oak Forest, Illinois
    I am finishing up a new batch right now. Then they need to go to the powder coater. It will probably be 2 weeks before they are ready.
    Jeff
  5. #25
    Feb 2011
    Mobile, al
    Lextech, sir I sent you a PM with some questions.
    Regards,
    Jose
  6. #26
    May 2007
    Quote Originally Posted by pacobeagle View Post
    I have no PM.
    Jeff
  7. #27
    Feb 2011
    Mobile, al
    Hmm, I'll send again, thank you.
    Jose
  8. #28
    Are these still $220?
  9. #29
    May 2007
    Quote Originally Posted by crzy8mnky View Post
    The kits are $250.00 shipped in the USA. The kit was designed to use the Gen3/Gen4 type alternator. I have 3 different Gen3/Gen4 alts and the kit fits all of them. The alt from my boys 98 GMC Jimmy will fit with a slight bit of trimming to the aluminum bracket that is supplied in the kit. The stock alt from my 98 fullsize also fits even though the kit was not designed for it. So, my point is---If you are using an alt that the kit was NOT designed for you may need to trim the bracket a bit for your application.
    Jeff
  10. #30
    Nov 2013
    Fort Hood, TX (for now)
    I'll be doing the LQ9 swap to my '98 RCSB probably around labor day weekend, will you have a kit available then?
