Page 44 of 44 FirstFirst ... 34 42 43 44
Results 431 to 434 of 434
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #431
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by smkur50 View Post
    been reading this thread for a few months..got any updated pics of it wrapped up? You use stock fuse panel to integrate the ignition and battery supply to the sensors and ECM?
    Sold. The truck about a year ago I ran everything through the ls pcm and stock fuse box.
  2. #432
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by HPICamaroSS View Post
    Good to have you back Ray, the 95 will be way easier since its not a vortec
    Yea it will be a while I'll start a build thread Soon as I do a few upgrades. Might hold off on it for a while because I want to put a 6.0 in a 96 impala ss.
  3. #433
    Sep 2011
    Atlanta Ga
    so the 95 was stolen...
  4. #434
    Mar 2017
    Nampa, idaho
    How did you get the key to start the 5.3? I can't find the wire for the ignition switch for cranking. I found 2 wires that have power in "on" and then when you crank it they go dead. I'm using the stock 5.3 fuse block and untouched harness.
