Results 1 to 10 of 10
Thread: Tailgate noise...
    Mar 2006
    Mesquite
    Tailgate noise...
    I hate rattles and noises when driving.
    There are two things that are annoying with the Silverado tailgates:
    1.) The stock location of the latch posts typically leaves enough slack so that you can move the tailgate back and forth (toward and away from the cab). This has been addressed before and is kind of a no-brainer, but if you remove the taillights, loosen the bolts holding the latch posts on, and move them forward (toward the cab) as far as they will go, this will typically pull the tailgate far enough ahead when you close it, that it eliminates the back and forth movement.
    2.) The passengers side 'pivot' at the bottom of the tailgate has enough of a gap that it allows the tailgate to move up and down. You can physically lift on that side of the tailgate to see what I'm talking about. So that, coupled with the above issue makes for a lot of racket coming from the back of the truck when you hit bumps and whatnot. I had one of the very large zip ties (3/8" wide or so) and tightened it around the pivot post. It took some shoving to get the pivot pocket to slide over the pivot post due to the thickness of the zip tie, but it went. There are a couple of benefits to this: not only does it eliminate the tailgate movement but it also adds some friction when opening the tailgate...not exactly Tailgate Assist, but close.
    Anyway, I have zero movement in my tailgate now. The zip tie will break over time I'm sure, but it should last for quite a while and will be an easy fix when it does break. Oh, and buy a black one so it blends better than the white one I used. It'd also be a good idea to throw some grease on the zip tie. Might extend it's life some.
    Good info Moze. My tailgate has pretty much always been noisy. When I get home tonight...well it will probably be tomorrow since I have class tonight....Im gonna see if these adjustments make as much of a difference as yours.
    Do you have bionic ears im replacing all the rubber on my truck cus im tired if the squeeking, but the tailgate rattling guess ivenever heard it before.
    01 GMC REG CAB BUILDING
    06 SILVERADO SS 80E 3200 YANK LS3 TOP, DD
    2013 POLARIS RANGER CREW LE EPS
    Quote Originally Posted by A PATRIOT View Post
    "MOLON LABE"
    Mar 2006
    Mesquite
    Probably all of the coats of paint on yours filled in all the trouble spots.
    Orono, ME
    2012 Honda Civic Si - DD
    yea never thought of that
    "MOLON LABE"
    San Marcos Texas
    Weld it shut or get a louder stereo!
    You mentioned g having too much paint so its held tight...maybe you can use ur left over bed liner and roll some in the jams of the bed so the tailgate is tight when shut too...
    Quote Originally Posted by GMCwantsLS1 View Post
    Or get rid of the old man exhaust, buddy Chris heard me coming literally three miles away from the house I was at WOT and on both stages but still
    "MOLON LABE"
    Round Rock, Texas
    Could probably hear your machine gun for 10+ miles...
