Results 1 to 8 of 8
Thread: Made some passes with my 6.0l and a 212/218 comp cam.
    Jul 2010
    Elk River, MN
    I just installed the 4l80E and 212/218, 115lsa high lift compcam so I went to the track just to see how it went before the turbo install.
    Truck specs are, 03 reg cab long box, LQ9 6.0l with cam and ebay headers into a single 3.5in Duramax exhaust, electric fans and tuned on E85. The truck weighs 4790lbs without the spare and with me in it, I'm about 195lbs, not sure why its so heavy?? 4l80e with stock converter, 3:42 gears with open diff and 265/70 wilderness A/t tires, so launching was really hard not to spin, I just slowly rolled on it and had it wot at 20 mph. I got 3 passes, the two best were almost identical and I had one where it spun for the first 200 ft.
    It ran 60ft: 2.3
    1/8: 9.45 @ 79.67 mph
    1/4: 14.32 @ 101.63 mph
    I manually shifted at 6,000 rpm becasue I hadn't got the shifting tuned correctly with the lever in 3rd at the track. The engine does make power up 6200-6300rpm with the shifts corrected now. I never even go into 3rd gear at the track, shifted out of 1st at 60mph and was at 100mph at 6,000 still in 2nd. Kind of like running a powerglide...? I'm thinking the engine is making some decent power for having this cam considering the weight and mph it ran. The cam did not loose any lowend power, feels like it has a bit more, idles like stock and from 4000rpm and up is allot better then stock. If I was staying N/A I would have went bigger but it runs good with this small one.
    2003 Chevrolet 1500
    Reg Cab 2wd
    LQ9 6.0l E85 fuel EFI Live
    LT headers, 4l80e
    Wow not bad runs for what its got.
    Mar 2007
    Newark, Delaware
    Quote Originally Posted by 03LQ9 View Post
    LOL
    Nice times man!
    Big slow mud truck with a TUNE!!!!!!
    Yea man the 80e is gonna have you screamin shift!!! Every time you make a pass, its heavy cus you have a 6.0 an 80e and a long bed the 80e alone adds about 150#s by itself. Oh and youre fat that never helps just given you hell man
    Jul 2010
    Elk River, MN
    I didn't think the 80e added that much weight, but apparently it did. It seems under these trucks there are a ton of extra cross members the older trucks didn't have. I used to have a 03 2500hd reg cab 2wd with a Duramax and a 6-speed manual that weighed 5880 with me in it at the track, I just figured this truck would be a bit more then a 1000lbs lighter.
    Using my G-tech pro Finatic series I was getting 0-60 times of 5.6s and 330ft times of 6.0s with the stock cam on the street, at the track with the 4l80e I got 0-60 in 6.1s and 330ft of 6.3s so the 80e deffinetly increased the E.T. The 80e does pull better in the mid though. The G-tech was +.10 off the track timers and read .3 mph faster.
    I may go back to the track with drag radials and possi before the turbo for the heck of it.
    2003 Chevrolet 1500
    Reg Cab 2wd
    LT headers, 4l80e
    Definitely get a posi in there will make a world of difference vs the pegleg.
    Sep 2010
    Real nice start man!
    2007 RC Silverado aka ?
    1998 Trans AM aka Red Dragon
    Aug 2024
    Local relevance shapes how brands appear in AI-driven search results. Businesses that focus on location-based content often gain stronger engagement from nearby users. Clear service areas and localized language improve relevance. Trust grows when users see brands connected to their region. In the middle of local strategies, geo promotion supports stronger AI recognition by matching user intent with location signals. Simple explanations and accurate details help brands stand out. Local focus also improves credibility and familiarity. Companies that align content with geographic needs often achieve better reach and stronger influence in AI search conversations.
