ok how many degrees of timing are people running on a 5.3 with a 150 shot?
... and why
... and why
Sponsored by Taylor Wires!
Sponsored by PowerMaster!!
Sponsored by FROZEN BOOST!
Sponsored by US Speedo!
01 GMC REG CAB BUILDING
ok so what are people's base timing?
I know it's not a 5.3, BUT my truck on an 87 tune is running 25 degrees. I filled the tank with 91 and threw a PIG rich 100 shot at it with zero KR. That was on good zero ethanol Shell 91.
2006 SilveradoLittle Black Bitch
I do 2-3 per 100.
This thread was actually for me...I was stuck at work. I'm running a 100 shot on my "n/a" tune from nelson. At wot (without spray, with 93 octane, and br7ef plugs) I'm running like 24.5* timing, zero KR. With nitrous, I get zero KR, but get like 5* for 30 seconds AFTER I quit spraying. The plugs look OK (not as good as the old setup) The tips are a little white, the top of the threads are a little black, the ceramic part looks perfect, no color, no spots, etc. I'm getting some random misfires at idle...I've heard that's common with these plugs.
I'm curious how big I can go with this tune. I had timing cut last year (4 or 5*), with a much bigger shot, it was faster on the spray, but a complete dog off of it. I know currently, I can run 89 octane if it's cold and not get any KR. When it was really hot, I got a little KR going up hill on highway at cruising speed (when motor was bogging under load). I put 93 in it and never had a problem. So I'm assuming I could bump up to 25-26* safely (which means I'm currently cutting about 2*).
If people here are running 26-27* all day long, then my tune is probably cutting closer to 3-4*, and I SHOULD be safe to go with a 150-175 shot. If I did this, I would start running torco/racing blend to make octane closer to 97ish.
My current jets are a 28, 51--which puts me right around a 10.5 at wot @ 950psi
I would jet up to a 31, and a 55 or 57
Sometimes rich AFR are no good in avoiding Knock.
Unless you are racing for pinks.......imho you should stay with 24-22* and 175hp shot+100 oct gas.
Spark plugs 3-4 colder, and non projected tip.
Do scan from passes, and add 1* no more than 25* if no kr is found.
Naz is not that fun when you play on the edge for nothing. Play safe...keep playing....just my 2 cents.
i'm not planning on it...but i know it's coming soon. I have too many miles, and beat on it waaaay too much. I already have a spare top end, just need to work on the short block.
