Results 1 to 10 of 44
Thread: Lifting heads at 19 psi?
    Jan 2006
    I have a friend running a 408 with L92 heads. He is running an F1 supercharger in a 57 chevy. He us running 19 psi and keeps lifting the right bank head? The block is fully studded also. He was wondering what heads had a thicker deck to keep this from happening?
    12 Sec. Club! SOLD
    SOLD***
    Oct 2007
    Bandera, TX
    L92s have the thinnest deck of all the stock heads... But not sure why he is having so much issue. I've seen guys run 18 psi on them with no issue. But to answer your question, any of the other heads will be thicker, 317s are the best for boost, buy they are cathedral port heads. His best bet is to go with some good aftermarket heads. Hope this helps
    single digit street truck
    for build info
    Pittsburgh, PA
    its more prone to lift the passenger side cause of how the cooling passages are, its also more common to over heat the cylinder on the driver side as thats the dead head of the system. To help aid in lifting a head you MUST keep the motor cool and when i mean cool im talking coolant temps in the 160s. Running standard temps with now a forced hot air going into motor will cause issues. the cooler the air the more dense it is which will help keep cylinder pressures down. The L92s do have a thinner dek but should hold if everything is in order for most part. Once you start making big power that is when other variables come into play
    Quote Originally Posted by Jamest View Post
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jan 2011
    i agree with keeping everything in check but tuning can also have something to do .
    6 bolt heads and 1/2 studs are what i did to prevent this.
    2008 Silverado 3500 LTZ 8"lift 37x20's
    2004 Silverado SS -427 lsx/TT/80e
    First 10 second Silverado SS 10.7@130 Video
    L92 heads are fairly notorious for pushing water.
    Pittsburgh, PA
    I just love net Sayers that don't have actual knowledge on subject to chime in.
    some ppl are pushing good power with ls9 ls3 l92 lsa heads and aren't having the issues others claim
    412 Motorsports
    Round Rock, TX
    Tune!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Jan 2011
    i was just posting what i did to prevent lifting and from my experience lifting a head on my 370 (arp studded 243's)from running excessive timing with boost and nitrous . ill shut up now.
    Regardless of what you did, they are still notorious for pushing water more easily than the other LS heads. Just because some people don't have the issues, doesn't mean everyone is that lucky. I'm sure good tuning has a lot to do with it, but they still push water more easily. Facts are facts.
    Put 1/2"-13 studs in the block and machine the heads for them. The 11mm-2pitch thread is .0769 and the 1/2-13 is .0787 spaced. This is a very common mod engine builders are doing to secure the heads on really HP engines.
