schoenfeldheaders.com the painted ones are much cheeper. there made for ls obs swaps good price for the painted one ther ceramic coated ones are a lil more.
Thanks, I just swapped a 6.0 into my 93 z71. U will love it when ur done.
Youngbuck, any pointers or info you could pass along would be appreciated by both of us
young buck. wat furl pump did u use? and did u have to use 1inch set back plates or transdapt. and did u have to use the flexplate spacer?? thank you if u could help me. thanks
I had shop do the swap, but I bought the set back mounts but he had to customize them to make them work. He just found a pump tht fit my tank not sure what kind but it supplys the psi the motor needs. An I swapped in a 04 4l80 so it bolted right up. I can findout more so feel free to ask.
