yep very costly...some of these shops just dont know much about these ls motors...not like a sbc.
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
Should hear from them today about what happened and if its going to cost me. Wish me luck!
Good Luck. If they don't make it right get a long block from proheads.com you wont have any problems with a motor from them.
Well I still have not heard from them. They said they were going to tear it down wednesday morning and see what the problem was. So hopefully it was something with the original build they did and I'll get a call saying to come pick the motor up. He said he was going to call if it was going to cost me some money... keeping my fingers crossed
Well talked to the machine shop. They said its the number 8 rod bearing and all the others show signs of wear. They said it looks like it could be from detonation. Any thoughts?
1700 miles should not show any wear. I am leaning toward builder error.
Even if I was having detonation?
What did all the other bearings look like? I'd go up there and inspect and take all the parts to get a second opinion.
A while back, we had this 6L GTO engine built, took three times and two different shops. In the end, it still wasn't right, I told the customer "if you buy a new block and crank and it doesn't fix it, I'll pay for it"
Ended up being some freak issue with the block I guess, cause the new block and crank fixed the oiling issues. This engine kept eating up crank and rod bearings around 1000miles. Indicator was low oil pressure.
Probably the shops fault cause both of them should have caught whatever was wrong, but sometimes it's just better to...
I'm not saying your truck isn't strong, but at that power level, I really doubt you tore your engine up with detonation. Wheatley knows where the timing needs to be, there is no way that tune would kill your engine with detonation issues.
I would check the other bearings and make sure it's not an oiling issue, crank walking, etc.
Good luck,
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Sounds like they are looking for a out. Even before I read nelsons post, I was thinking after you talked about detonation, that Charlie knows what can and can't be done..
John
JOHN
