Results 1 to 10 of 16
Thread: 99 lq4, 243 heads, comp cam, dyno run
    Sep 2010
    middle tennessee
    Here is the video of the dyno run I said I would post. Its from last month when my brother and I had access to a dyno. This wasnt the best run of the day and we are still trying to learn how to tune with ls1 edit, but it is what it is... enjoy!
    http://www.youtube.com/watch?feature...&v=rGgJJQ4StU0
    99 silverado 2500 4x4 ec lb, lq4 with 243 heads, pace setter long tubes, true duals with x pipe and bullet mufflers, comp 222 224 112 cam, 8.1 truck injectors, 4l80e with 2800 stall, 373 gears, 285 75 16 tires, efi live tune in progress, 350rwhp 360tq, 11.8 average mpg mixed driving
    Those are some low numbers for a cammed 6.0
    I know its a lq4 but my lq9 with stock cam, 317 heads, and stock intake with a 89 tune made like 324/345
    Jun 2010
    West Texas
    Sounds good! With that motor, a bigger cam would help out alot, Im sure you already know that, but its got potential.
    RUN WAT U BRUNG!!!!
    Mar 2007
    Newark, Delaware
    I think those numbers are decent, considering it's running through a stalled 80E and 285's.
    Quote Originally Posted by Beatdown Z View Post
    Mine was with a stock stall 80e, and 14 bolt. Track times show me making around 480 now... But its not about who has the most power, again I just thought those were some low numbers for his mods.
    Sep 2010
    middle tennessee
    The tc was locked in all the runs so that isnt an issue. If those numbers are low what would you say I need to change? I know a bigger cam would net better peak numbers but i stll tow with this truck and need it to be suitable for daily driver duty if and when my 250,000 mile beater car dies.
    Jan 2010
    Cedar Park
    I would say keep working on the tune cuz i have seen 5.3's in that power range. Your cam is smaller than my 5.3 cam but its probably better suited towards your stall
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
    Elsa RGV & San Antonio TEJAS
    Quote Originally Posted by aj06bolt12r View Post
    considering the above, i would say swapping to a tbss or nnbs intake and possibly some porting to the 243s.....intake would def help and would be 1st on my list and then work on heads, and of course retuning. you would get what you want and be happy..... good luck....
    Jan 2006
    Mine stock only made like 220 At the wheels. Of corse on the stock tune.
    12 Sec. Club! SOLD
    SOLD***
    Sep 2010
    middle tennessee
    Quote Originally Posted by Jamest View Post
    All stock was 220 at the wheels you say? Well I guess if I picked up 130hp with these mods I probably shouldn't complain. Thanks for the info.
