Results 1 to 9 of 9
Thread: tensioner relocator for car intake and truck acc setup
    Nov 2010
    Motown
    gonna need one of these till I find a whole f body acc drive. I see some for sale here and there on pt, and ls1tech, but always am too late. Anyone know of a link or someone selling one. Need one asap... Also can you still use the stock belt, or do you need a differeent size one
    Having a 12 second Honda is like coming out of the closet. At first all your friends are amazed, but in the end you're still gay!
    00 YUKON THE DAILY TROOPER
    16" 2 CYCLE SCOOTER AKA(THE BANDIT)
    95 STROKED IMPALA SS (THE LOW 12'S SLEEPER) BLOWN
    BUT COMING SOON BIGCAMMED6.2, AND WHOLE LOTTA JUICE
    IT HAS BEGUN!
    Aug 2009
    Devine, Texas
    Check out http://www.schwankeshortblocks.com/shopping/?ic=1216 give them a call they should have what you need.
    LS6, 222/224, Yank ss3600, 4.10s, Thorleys, HP tuned
    i used the truck tensioner just modified it,moved the idler to the center bolt of the alt pws bracket, uses different size belt. by the way this is with the truck acc. did have to space out my ewp
    Simple: 408 on steroids!
    single digits coming soon!
    New Orleans
    i have the speartech idler re locator bracket with an underdrive pulley and a overdrive alt pulley and a stock length belt works perfect
    07classic
    !MY GARAGE!
    Jan 2005
    Humble/Houston TX
    Quote Originally Posted by skeet View Post
    i did the same. adle pulley relocate= a LONG bolt and some flat washers.
    old mod list: H/C/I/N/E/G 408
    new mod list: 5.3, gears/posi, mufler and tune : (
    Nov 2010
    Motown
    Skeet, and Tx. Can you post up a pic, and about how mong do you need the bolt to be????
    IT HAS BEGUN!
    Quote Originally Posted by chacho44 View Post
    So Cal
    Lil off subject but skeet what kind of water pump is that?
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Quote Originally Posted by DAmarcus28 View Post
    Meizer electric.
