Results 1 to 3 of 3
Thread: GSS Speedshop - Carrollton, TX
    Mar 2006
    Mesquite
    Posting this for guys that need work done locally in the Dallas area:
    The owner of this place helped a lot on the black truck when I had it. Helped me get the alignment where it needed to be, suspension, etc. If you're local and need any of the following done, give them a shout.
    Basic to In-Depth mechanical work
    Road or Drag Racing alignments
    Corner Balancing
    Fabrication
    Just an example of how much alignment affects performance: We were at the Texas Mile this past weekend and a Supra made a pass at around 190mph. The driver said it started getting pretty loose at the big end, so he let out. He adjusted the alignment and the driver went back out and busted out a 230+mph run. Huge difference!
    Quote Originally Posted by damnyankee View Post
    posting this for guys that need work done locally in the dallas area:
    The owner of this place helped a lot on the black truck when i had it. Helped me get the alignment where it needed to be, suspension, etc. If you're local and need any of the following done, give them a shout.
    Basic to in-depth mechanical work
    road or drag racing alignments
    corner balancing
    fabrication
    just an example of how much alignment affects performance: We were at the texas mile this past weekend and a supra made a pass at around 190mph. The driver said it started getting pretty loose at the big end, so he let out. He adjusted the alignment and the driver went back out and busted out a 230+mph run. Huge difference!
    wow
    Houston
    Quote Originally Posted by zeake View Post
    wow
    we dont play around here in Texas
    Saw these guys out at Texas Mile this sat, had alot of nice equipment out there to help everyone out, great group of guys
