Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Turbo 4.8L questions
  1. #21
    Pittsburgh, PA
    each side of motor should be vented, if you can pick up a LS6 valley cover and vent the valley of motor as well
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #22
    Oct 2009
    Katy ,Texas
    interesting
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
  3. #23
    The Garage
    I'm starting to agree with George. I had an improved STS PCV setup and even with the catch can I was still losing oil. I pulled all that crap off and just put filters on the valve covers. I'm hoping to at least see LESS oil consumption. From what I hear, oil consumption through the PCV increases heavily with a turbo'd engine. Hopefull the KISS solution will remedy the "dissapearing oil" problem
  4. #24
    Dec 2013
    what heads to use for boost? By the way what is the set up in your truck
    Quote Originally Posted by jetmech View Post
    You've explained your plans but what exactly are you asking? I'm running a turbo'd 4.8L and I think I can help but I'm not sure what information you're after.
    what heads will work on my 4.8l so I could boost it?
