Results 1 to 5 of 5
Thread: LQ4 piston, rod and seals NEEDED..
    Dec 2008
    La Porte TX
    I am looking for one piston, rod with the seals.. Hit me up if you have one available. If local, I can meet up
    where ever. Live in La Porte, work in baytown... 281 five zero eight 4535
    5.3, small cam, 918 springs, 7.4 rods, walboro pump, Full built 4l60, 2800-3000 stall, TB spacer, long tubes, cat delete, single 3" exhaust with Aero bullit muffler. Flaco tuned.
    Aug 2005
    houston TX
    i have a set what seals are you talking about
    03 1500HD 4x4 6.0 on 33"
    K&N intake, Pacesetter LT, 3" true dule orp, Magnaflow, Comp cam 237 242 .603 .609 112, Patriot Gold springs and Ti retainers, stock ported heads, ASP Underdrive pulley, 42# injectors, 160 tstat., 05 E-Fans, Nelson Fan Harnas, tb bybass, MSD wires, NGK tr55, Ported tb, Transgo HD2, yank 3200 conveter, HP tuners, Walbro 255, 4.56s
    Dec 2008
    La Porte TX
    I ment rings. I was being retarded that day i quess. You can give a call and i willcome get it. Number is 2815084535
    Dec 2008
    La Porte TX
    Ttt
    Dec 2008
    La Porte TX
    Ttt
