Thread: Fuel pump? I think
    Oct 2008
    Cedar Park, texas
    Fuel pump? I think
    Weird problem with my truck, Every morning i start it up and let it warm up a bit. It drives fine for the first mile or so then begins to hesitate very bad and makes popping noises from the engine bay. It does this only up until about 180 degrees, then drives like normal. cleaned the MAF,IAC,MAP and air filter, New plugs and fuel filter also with no results. Any ideas?
    Axekick tuned, Pacesetters, Servo.
    Jun 2010
    San Diego, CA
    Check fuel pressure at the rail. Any noise from the pump?
    1997 4runner
    1978 Jeep CJ7 with a 2002 5.3 engine
    Southern WI
    Possible, but to me seeing that it's temperature related I would also try the temperature sender or the coolant temp sender (yes they are different). If the gauge reads good and isn't acting up then I would rule out the coolant temp sender and just focus on the temperature sender as it communicates with the ecu.
    Mike
    2000 RCSB
    Oct 2008
    Cedar Park, texas
    Quote Originally Posted by collin View Post
    Yes, the pump makes noise
    Quote Originally Posted by 1_fastsilverado View Post
    It has a new coolant tempature sensor, witch other one are you talking about?
    It was doing the same thing tonight, again up untill 180 ish. Im stumped on this
