Results 1 to 6 of 6
Thread: Repair your GM 03-06 guage cluster
    Aug 2005
    St. Anthony, Indiana
    Are any of your gauges sticking or not working at all?
    Here is how to fix them.
    Parts needed
    solder gun
    new stepper motor
    1. make sure vehicle is completely warmed up, this is for when you mark the needle position.
    2. Remove bezel.
    3. Remove 4 bolts holding cluster, and then unplug cluster.
    4. Remove front of cluster. 3 clips on top and 2 clips on bottom.
    5. Put on blue tape to mark needle position.
    6. Plug cluster back into vehicle. Start vehicle and mark needle positions. Turn vehicle off and mark needle position again.
    7. Gently pull off needles.
    8. Pull off gauge face.
    Here is what it looks like after needle and face removal.
    9. Now you need to remove the back plate. 4 clips on top, 3 clips on bottom.
    10. Determine which gauge you need to fix. Do not apply a lot of heat to the circuit board. Apply just enough to liquefy the solder, and pull the stepper motor out. There is 4 solder points for each stepper motor.
    11. After stepper motor is remove, put the new stepper motor in and re-solder.
    12. Reassemble in reverse order, but do not attach front of cluster at this time.
    13. After needles are in place, plug cluster into vehicle and check needle placement with vehicle warm.
    You can verify mph needle placement with a GPS unit.
    14. Once you are satisfied with all needle placements, you can install the front of cluster. Install the cluster in vehicle and reattach bezel.
    Round Rock, Texas
    Great write-up. I want to know if I can add the trans temp to mine. All I need to buy is one stepper motor with needle and the HD gauge face, correct?
    Aug 2005
    Quote Originally Posted by Duct_tape123 View Post
    I already tried that, but the gauge cluster has to be programmed for the new gauge.
    Nov 2009
    Indy
    So does that mean it can be added, but just needs to be programmed for. If thats the case then I am going that route instead of paying someone for a whole new cluster just to get a tranny guage. Can the stepper motor go in any way or is there a certain clocked position????
    2004 GMC Seirra 1500: 3" Body lift, 295/75 Nitto Terra Grapler's on Stone Crushers, cam keys, Bilstein 5100, 5.3 liter, K&N 77, Stainless longtubes, Banks Monster Exhaust, Nelson Performance 93 tune, 2600 stall, Ls1 fans, Taylor wires, NGK tr55's, TransGo shift kit, Corvette servo, TCI pan, 4.10 G80 w/ TA Performance, Optima
    Round Rock, Texas
    How and who can program the clusters? I would love to be able to add the trans temp without having to buy a new cluster.
    Aug 2005
    Quote Originally Posted by Next Level View Post
    Yes, you can add it, the spot is on the circuit board for it. If you look at the second last pic above you can see where the stepper motor will go. You will also need to add a light for that gauge. The stepper motor can only go in one way. You can look on ebay for someone to program it. I would think that most of the people offering rebuilds can program it for you.
    If interested I have a new gauge face that has the trans temp on it for sale. i also have some needles for sale, depending on what length needle stem you have.
