We have been working on some new kits for the truck market. Knowing how times are getting tougher and money is getting tighter. We have come up with some kits that are very cost effective.
Not only are these kits cost effective they are very easy to install.
Once the stock crossover is out you should be able to have this kit installed in under 4 hours.
On the Stage 3 the intercooler comes with thick steel brackets to mount your IC directly to the frame. No need to fabricate brackets or try to figure out how to mount it. All the aluminum cold pipes are cut to length and bead rolled ends. Making for a clean install that will not blow apart while under boost.
The hot pipes use our swept runner thick wall manifold, and aluminized tubing for the crossover and the downpipe.
3300.00 + freight.
This is our 99-06 Stage 3 kit.
- Swept runner thick wall turbo manifold
- 70 mm turbo
- 38mm gate (vented to atmosphere)
- blow-off valve
- Mandrel bent aluminized steel crossover and down pipe
- Air filter
- Cold piping with bead roll (NON-mass air meter)
- 3” throttle body cold pipe
- Stage 2 intercooler with mounting hardware
- Silicone couplers and clamps
- Oil pressure and return lines
- Oil pressure and return fittings
- 02 bungs
- heater hoses and clamps
- vacuum lines
- washers, bolts and nuts
(This pic shows all the parts that come with our Stage 3 kit.)
As all of our kits there are 4 things you will need to complete the install.
Final exhaust (diesel 3.5" or 4" on very resonable.)
Inejctors
Tuning.
electric fans
We feel these items are best purchased by the end user. If We were to buy them we would need to mark them up costing you more then if you purchased them yourself. And the whole idea here is make these kits more resonable.
Feel free to lets us know if we can help with your turbo project.
