Your going to want the wideband pre catylist. The converter will change what it reads and make it where you cant effectively tune it. Plus the converter is another variable that is constanly changing in different conditions. OEM's use the forward 02's for fuel control for those reasons. Im not sure what a wideband will read mounted after the catylist but it will most definately read something completely different from what the actual a/f is either lean or rich. I want to say it will read rich but i cant remember this morning for some reason. If you mounted the wideband after the cat and you had tuned it off of that somehow and say your cat went bad (lost efficiency P0420, p0430) the wideband would read completely different and throw off your whole tune. Put it in front and you will be ok.
EATIN' FORDS AND TUNDRAS
RIP 2005 VHO ecsb 6.0HO, Comp Cam, Nelson Tune, OBX LT's.
