Right here, just stupid.
You are heating a pressurized cylinder with a flame from the coals, if your lucky the disc will blow before the cylinder does killing or hurting anyone in the area.
Not a torch but still an open flame heat sorce.
Online Store
[/CENTER]
the torch is very bad idea since it puts a concentrated heat spot on the bottle.
i seen a bottle let go. it was sitting on a trailer with a blanket over it to keep it out of sun but the heat just got to it. this was mid July. The bottle became a missile and flew around for a few minutes damaging a couple trucks and destroying itself banging around.
i know some sanction races will ask you leave the race if they see you using torch.. Its just to dangerous
2014 Xsport- 3.5 Eco boost
412 Motorsports
as far as loosing traction yes suspension mods are a great start do you have any traction bars? caltrac traction bars are the shit. also heat the tires up do a fatty burnout. i use the exact same tire on my vette spraying a 150 shot making over 600 rwtq and it hooks everytime leaving at a 4k dump
00 silverado superbrick
supercharged
02 ss camaro
all motor
99 frc vette
bottle fed
