Results 1 to 7 of 7
Thread: cruise control conversion ?
    Dec 2009
    Question cruise control conversion ?
    Need some help. I would like to keep my cruise control thats in the truck. How can I run it through the factory switch on the column or can I? The engine is out of a 08.
    Wichita Falls, TX
    Are you going with a drive by wire or drive by cable throttle body?
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
    Dec 2009
    lowchevytrucks, The engine is dbw
    Wichita Falls, TX
    i new the engine was but didnt know if you swapped tb's. I dont know how to answer your question but i'm doing the same thing and was told there's only 2or three wires to hook up to the throttle body. let me do some thread reading.
    2003 SIERRA- 5.3 DD
    Nov 2009
    Fort Smith, Arkansas
    This is for a different year donor and recipient but it might be the same or close to it.
    http://www.ls1truck.com/forums/lsx-t...-diagrams.html
    Check post #5
    Wichita Falls, TX
    this is going to be quite a bit different from a '93 because the cruise controls on these older trucks ran of vacuum..........
    Still doing some thread reading......
    2003 SIERRA- 5.3 DD
    why not upgrade to the electronic box?
    If you have the electronic throttle pedal then wiring up the cruise will be nothing more than wiring the stock cruise button into the PCM properly. If you have a throttle cable then you can wire in an electronic style cruise box from a later model.
