Results 1 to 6 of 6
Thread: Paging Allen or anyone with HPT experience, glitch on the 2/3 shift at dragstrip
    May 2007
    This has happened to me twice now on different nights. I use the box to do stand alone logging.
    Right before the 2/3 shift the motor acts like it hits the rev limiter and the tranny wont shift. However the rpms are nowwhere near the rev limit. It almost seems as if the ignition just shuts off. As soon as I let off the throttle everything goes back to normal. I can get back in the throttle and its like nothing ever happened. This has happened twice with 2 different tunes so I don't think its related to a specific tune. Also, I think it might be HPT related cause the err light on the box blinks till I clear it. Commanded shift rpm is 6900, rev limit is set to 7500, log stops recording at 6600.
    Does anyone know what this could be???
    It's always a good big accomplishment to get such a big build running. So congratulations on that!
    However, you're already talking bs and the truck is on jack stands, lol.
    Get it on the track, run some respectable times, then say "to all the haterz" because that vid is weak lol.
    You got a long ways to go to compete with the turbos!
    Quote Originally Posted by 2boosted View Post
    Sorry dude....what I meant is that you are full of shit. Your supercharged turd wont ever make it to the 8's and your wasting energies as Casey did.
    Go turbo and be done with it.
    newburgh, NY
    What is your shift mph set at? if it is to high it will act like it is hitting the rev limiter.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    San Antonio, TX
    If the tune hasn't changed much, the mph shift points will be lower than the RPM shift point.
    With your vehicle, the rev limiter should feel like the truck just stalls or doesn't accelerate, is it doing that, or is the engine popping or backfiring?
    May 2007
    I sounds to me like it backfires, but everyone in the stands was like "why did you let out of it". It feels just like the rev limiter, but the truck doesn't do anything till I let off the throttle. Also, the first time it did it the mph was higher than the rpm shift points, this time the rpm was higher than the mph shift points.
    One thing that I just thought of, I've heard of guys (Flaco for sure) who have had the electronic throttles slam shut because of so much airflow, could this be the problem?
    Sounds like a simple loose connection although I wonder why you have all those parameters set so high.
    May 2007
    Because thats where it makes power.
