Page 7 of 13 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 61 to 70 of 124
Thread: Dragalanche new turbo setup
  1. #61
    Quote Originally Posted by Turbo6.0L View Post
    Allen,
    Like how you turned the drain on the hx to an air bleed. Really nice idea. That dual cross flow set up is a nice unit for sure. Used them in the past. Just remember to set your water pump below the water tanks lowest point. Helps keep it from cavitating. The water tank also needs to be above the IC or it may drain back wards giving you air pockets later or even a messy floor.
    I have an inline radiator cap to install, gonna put it as the highest point, weld it to the side of the a/w intercooler.
    I have the pump mounted below the heat exchanger, check out that last pic.
    I'll add the watertank later, right now we'll see how well it cools. I'm thinking of installing the watertank in the corner on the passenger side.
    later,
    allen
  2. #62
    Gramercy
    how much just a/a cooled vs your a/w cooler? id like to use my stock manifold too if possible.
    i love your work!
  3. #63
    ff_jeff Guest
    Quote Originally Posted by DBTBSS View Post
    $3k ... you better add 7 grand to that figure
    Looks awesome by the way! Who's going to tune it?
    Ive allready spent over $5k. I think All i need is a harness, tune, hot pipes and to put it all to gethe..... yeah maybe your right
  4. #64
    mesquite tx
    clean!!!
    ITS MATT SUCKA
    98 rcsb dd
    abosolutely nothin cept flo
    & Nelson Tune
    lookin for project
    bangbangskeetskeet: how big is it v?
    mean05: about 8''
    txarkitekt: I will drink you under the table!
  5. #65
    SugarGrove WV/Eubank KY
    ok i hurry up. lol
    we are getting anxious. lol
    01CamaroZ28
    10.751 @ 124.26 mph with a 1.446 60ft
    ALL THRILLS NO FRILLS!!!!
    B&L Racing stg 1 heads 224/581 cam.
    06 silverado 6.0L VMAX LPP LT's, Volant CAI, Manaflow, NELSON TUNE.
  6. #66
    Mar 2006
    Mesquite
    Had to use some post intercooler tubing for trucks running maf, or else it would be just an elbow from the IC outlet to the tb.
    Why does the piping loop down in front of the fans and then up into the throttle body? Can't you keep it short and turn it directly into the throttle body? Seems like all of that heat from the radiator blowing on the pipe would increase your IAT. Maybe I'm missing something...?
  7. #67
    Good question Moze.
    01CamaroZ28
  8. #68
    Oct 2007
    Bandera, TX
    i thought heat soak only happened to Ls???....lol
    single digit street truck
    for build info
  9. #69
    Mar 2006
    Mesquite
    No, that's "speed soak" you're thinking of, Mic.
  10. #70
    No, it's Speed Stick Moze.
